Two questions regarding curtain wall mullions.
1. Is there a way to "join" curtain walls at corners so they share a single corner mullion? Currently, both my walls have to have a corner mullion, which means at the corners I have overlapping mullions.
2. Is there a way to get horizontal mullions to clean up easily around a 90 deg corner mullions? See attached image. The top part is where I have removed the corner mullion from the left wall, but it is still there for the right wall. The lower horizontal is where I have a corner mullion (so 2 on top of each other) for both walls.
Thanks for any help.
Grant
Grant
