Column and Wall Connection with Wrap Problem
Unfortunately end wraps is not an instance parameter so you would need to split your wall and make a duplicate wall type with no wraps for the side touching the column.Scott D. Brown, AIA | Senior Project Manager | Beck Group
Hello,
as shown in the attached screenshot I have one wall and a column. How can I cut the wall to finish the column, as shown by the red line...April 21, 2012, 05:56 PM -
Hello everybody,
Is there any possibility to make the column look like a whole?
Is there a priority list in Revit?
April 20, 2011, 08:41 AM -
Hi all, I'm trying to join the column and wall shown in the image, but if I do it with the Cut Profile tool it I have to do each wall layer separately...July 17, 2013, 03:16 PM
So I placed a column inside one of my walls as such(picture 1).
But when in join them, the thickness of the plaster and...February 27, 2018, 10:54 AM -
I draw a column and want to connect an incline wall on plan as show in the picture. Pls show me how to do it? I have the same problem with colum also....December 22, 2015, 10:21 AM
Monumetric Footer In-screen
