Get all the junctions of walls/floors elements
    Hello,
    I would like to get all the intersections of elements (walls, floors) which make a room boundaries.
    For each of those, I need to get its length and the two ajacent elements (walls and/or floors) which make this junction.
    I tried using Room.Boundaries but when I get all the boundaries elements, how can I find each junction made by all these elements ?
    For exemple, for a given wall, you could have 3 or 4 different floors elements that make a junction with this wall.
    Many thanks in advance for your help!
    hey,
    can you show us what did you do so far? also, do you want to autojoin them using dynamo or any other goal?
      gui_foucart:
      Also after you post a screenshot, maybe identifying what you are attempting to achieve in the long run? What is the absolute final end goal? Are you just wanting a X,Y,Z point of the intersection of these objects to export to a .csv? Toggle a Yes/No parameter in the element that is has an intersection? etc.
      The answers can take us down different paths to solving the issue you proposed.
