How to change the letter size of a viewport?
    Hi, i need to change the letter size of a viewport, help please.
    Guess you are talking about the size of the sheet? you need to have the family with the dimensions you want!
    A little hint, if you include pictures in your post it will help us a lot to understand your problem!
    If you want you can upload the family in this thread, that way somebody can take a look of it and maybe help you to solve your issue easily!!, regards
    E.A Poe
      Or do you mean the Text size of things like Dimensions and Tags within a View that's placed on a Sheet?
      Text, Tags and Dimensions in Revit are PRINTED the same size regardless of the Scale on the View.
      If you need bigger Text, just make a new Text Type and the the font size to the height you want it printed
      Dave Plumb
      BWBR Architects; St Paul, MN
