what template do i need to choose for...
    hello
    i'm in a new company and i will have to make project for the bukding and the process
    i'm working on wastewater treatment plant and the drafts will be send to civil engineer and piping subcontractor
    with what kind of template should i need to start to create my new template?
    i don't know exactly the difference between the template but i know that i have to kind of drafts for 2 kind of subcontrator 3 with electrical)
    well, i'd just like to start with the good template but...
    any idea/purpose will be welcome
    Phil
    Freelance WWTP/HVAC Designer
    Revit 2019
    hi
    i know that there was some difference with old versions (2010 and olders) but with the new Revit which include Arch/Structure/MEP i don't see (on the screen) any difference...
    PHil
    Revit 2019
      Originally posted by philsogood View Post
      hello
      Phil
      Hello Phil!! the difference between templates AFAIK are mostly related to visibility graphics and OOTB setups and pre loaded content, I mean if you are working in a MEP template you will see most of the ARCH components in shades of gray or transparent but you can change the most part of those set ups to match your company standards, if the template is for civil purposes the most part of the objects will be transparent or in shades of gray as well, if you don't see any difference when looking at the scree is because probably you aren't drawing yet! , HTH
      E.A Poe
        Use the MEP template if working with piping...it has a lot of piping types preloaded to get you on your way. It is a pain in the ... to get them loaded in an arch project.
          Yup, use the MEP template or get your management to hire Aaron to get you a great template.
            thank you
            Colombian & US help is definitly very useful
            i can start now with many things/tips I pick a bit everywhere, many thanks to Aaron for its tips I discovered this morning "Building a Revit Template"
            Phil
            Revit 2019
