Is there a way to have exceptions for view range settings in a certain view? For example, I have an equipment plan. I want all thing that are in the category "Specialty equipment" to show up on the plan regardless of the view range. This would avoid having to do multiple plan views. I really want to avoid this.
View Range - Can you have an exception for a category?
Steve's right - families make a big difference. From what you've said it sounds like you have equipment that is above the cut plane? Adding an invisible line in the family that extends to below the cut plan will allow them to show up.
Plan regions can work, but are finicky - I've found that they often need to surround an entire element, which can cause undesirable changes.Last edited by jmk; February 25, 2019, 09:44 PM.Julie Kidder
Architect + BIM Director
I have three cylindrical tanks, each ten feet tall, surrounded by a platform (top of platform 8 ft). I am making two piping plan views, one below the...
Channel: MEP - General
September 11, 2015, 09:38 PM -
I have not noticed this before but I've encountered a problem but others have. While in 3D view, everything is visible. In the reference plan view, nothing...
November 30, 2015, 05:04 PM -
In Revit 2019, is there a way to "show in view?" Like the opposite of "hide in view?"
I have a plan that has a steeply...August 15, 2019, 03:43 PM -
how to create partial view range?
I was told that in revit 2013 we are able to create a box and change the veiw range ( different than the whole...-
October 22, 2012, 06:16 PM -
I've got a Plan Region that's not behaving as I would expect.
The model has a few upper cabinets that are lower than usual.
Because they...March 9, 2018, 06:02 PM
