I thought I was doing this correctly, but maybe not. Let me walk you through what I did.
I have a view. Floor plan. I copied it, left the discipline as architectural and created my equipment plan. Easy enough.
I then copied my equipment plan, changed the discipline to Electrical to create an electrical view. This view is grayed out like it is an underlay. Also, even though underlay is set to NONE, I can still change it from reflected ceiling to plan view, and the view changes accordingly like it is an underlay. My other views won't let me do that.
It seems to be happening only when I choose electrical or mechanical for the discpline. Is this normal behavior?
If not, what am I doing wrong? Why is this particular view behaving this way?
If so, how can I change that. Where are the discipline settings, or are they hard coded that way?
