So I know that I found a way to show the overhead lines for an overhang in a plan. But I cannot remembe how to get I to work. I thought that it was the linework tool...but maybe I'm wrong...
Showing overhead lines
This topic is closed.
What I've done in the past is go to a view where the overhang is visible. I then use detail lines that I want to represent the overhang in plan and pick the outline of the overhang and lock the lines. Then select the lines and cut (ctrl +x) from view. Go to the floor plan and paste align. If the overhang moves these lines should move as well...Chad Koscinski | Architect
It's indeed the linework tool. You need to use an underlay view which shows the overhead lines you want to see in your current plan. Select them using Linework and turn the underlay off. The edited linework lines should remain visible.Martijn de Riet
My prefered approach is to underlay a view that shows the lines, then use the Linework tool, then turn the underlay off. Like Chad's approach, if the overhang moves, the graphic in the plan moves, but without the need for locking. And once upon a time in Revit, too many relationships slowed things down. This isn't over-constraining, but every relationship adds to the processing load. Plus you don't actually add object (detail lines) to the model, you are just changing the representation of the model, which is a more "light weight" way of working.
Of course that was a rule based on much slower computers and perhaps doesn't apply as much any more, but I still like to work in a mode that focuses on "embellishing the model" rather than "drafting the view" if that makes any sense.
Gordon
EDIT: Martijn de Fast Fingers is more like it!
Chad, I doubt that the lines would move with the overhang, if copy/pasted as suggested (but have not tested)
Instead, temporarily change the cutplane of the view where you want the overhead lined to show, so the overhang becomes visible, and use the "Linework" (LW) tool. After that, just reset the cutplane, and the overhead lines will remain, and be "attached" to the overhang.Klaus Munkholm
Wow ! Is it not a great forum?
This question got 4 solutions in 7 minutes !!!Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
Originally posted by Munkholm View PostChad, I doubt that the lines would move with the overhang, if copy/pasted as suggested (but have not tested)
Gordon: I know, just happy to see (in a way then) you all again. Missed my AUGI-threads for a few weeks before I noticed this forum. That, and I am in between 2 large projects so I have taken a few days to fiddle with Revit all day. But I do have to cut down, my wife is starting to think I'm having an affair...Martijn de Riet
Originally posted by mdradvies View Post...But I do have to cut down, my wife is starting to think I'm having an affair...Klaus Munkholm
I have a general question that applies to a specific situation of mine...
What is everyone doing in their drawings in regards to adding additional...June 6, 2011, 08:23 PM -
I'm sure there is a way to show a canopy that is within the view range but above the cut plane. But I can't Find it.
A picture is worth...January 2, 2013, 11:25 AM -
I have some overhead lines I need to show in my plans. I set my underlay, use the linework tool, <Overhead Lines> - easy. But I need to show them...January 30, 2015, 02:13 PM
Is it possible to create purely dotted lines in Revit similar to AutoCAD?
Dotted lines seem to come out as dashed lines for me.January 26, 2011, 02:53 AM -
Is there a way to control the halftoned lines so they never take precedent over the solid lines? I've had this problem across printing platforms from...March 14, 2016, 07:24 PM
