Import a pds file to Revit
    Is it possible to import a pds file to Revit 2019?
    What's a PDS?
    FileInfo.com says it a video file.
    If that's really what you mean, then no.
    If you actually meant PDF, then the answer is: not yet.
    According to the Official Revit Roadmap, that idea has been "Accepted and "may be available for testing in Revit Preview"
    Revit Public Roadmap - September 2018 - Revit Official Blog
    Dave Plumb
    BWBR Architects; St Paul, MN
      If you have a version of AutoCAD, you can import a PDF and convert it to a DWG file, which can then be imported into Revit.
        Or maybe you mean a .PSD file?
        That sounds more likely, as that's Photoshop.
        Dave Plumb
