I have a window that is above the cut plane of the view, so I added a plan view and set it to cut the window. I know about the issue of the window family needing to have it's cut plan shown as actually cutting the window, which I did. The problem is, only half of the window is showing up.
I've tried different cut planes, symbolic lines, everything I can think of. Why would only half of the window show up?
By the way, there is a drop box I created that is under the window. That's what's showing up in the plan view as well. That looks like it should, though.
