I have a problem modeling a cinema
    Hello everyone, I am trying to model this cinema, but I am having problems modeling the floor. I created each step as a floor, but I can't join the concrete together, and I can't make the concrete sloped on the bottom. I also can't make place finishes on the risers. I am sorry if the question is a bit silly, but I am new to revit.
    Thanks in advance.
    Two thoughts:
    1) Build it as a "stair": the monolithic style would provide the sloping base you're looking for.
    2) This could be one of the few times an in-place family could be useful (could also be built as a generic model family).
      Normal Floors, and Normal Slab Edges, to create the underside.
        As CADiva says, build it as a stair. Here is an example:
        This is a view down into a model of a 60,000 seat stadium. I used cast-in-place stairs for the seat rows and for the traffic steps:
        The stairs can be "segmented' in plan to join at arbitrary angles. The joints between segments are geometric within the stair editor. The definition of each segment was done with a system family called "Monolithic Run". This was a continuous drawing process that can be started, interrupted and resumed with care. Although the joints between segments aren't exact, I left the work in this state and moved on because my purpose wasn't architecture but AV design - The model got close enough to illustrate the AV aspects.
        I hope this sets you on a useful path.
          Thanks for the replies.. They certainly seem helpful and I will try them as soon as i get some free time from uni.
