I'm very green to Revit, I'm hoping this is an easy issue to resolve. I am using a Howe Flat Truss family for my prefabricated roof truss. I've added an overhang parameter in the family. I set it to 3'-0", when I attach the top chord to the roof it removes the overhang. I'm a bit confused why Revit is removing the overhang after I attach it to the roof. Any help or advice would be greatly appreciated.
Prefab Roof Truss overhang issue
Welcome to Revitforum.
The issue is not quite clear. I see an overhang in the truss.Attached FilesFreelance BIM Provider at Autodesk Services Marketplace | Linkedin
I see. In that case, maybe you could:
1) Drag the width of the truss outwards to cover the overhang.
2) Drag the end of the bottom chord inwards.Attached FilesFreelance BIM Provider at Autodesk Services Marketplace | Linkedin
Hello I am having a bit of a problem with a roof truss. The roof truss editor is simple, with its lines.
Only problem is when you add a timber profile...-
October 24, 2019, 04:00 PM -
Hi All
New at this game but I would like to ask the best way, if possible, (other than pen and paper) to do simple roof truss calculation...September 8, 2012, 01:25 PM -
Does anyone have a roof truss with the top cord that is adjustable. need for a 1/4"/12 roof with flat ceiling attached to bottom of truss. needs...
Channel: Structure - Family Creation
February 3, 2015, 12:04 AM -
I need a truss where the bottom chord remains parallel to the top chord, when the truss is attached to a sloped roof.
I have searched everywhere...-
September 20, 2012, 08:50 AM -
In roof properties there use to be a choice between Truss or Rafter which determined at what point the roof pitched from, inside or outside of frame....August 9, 2011, 11:27 PM
