We are being asked to bring in underground utilities for use in revit. The civil engineer sent a dwg file with pipes in it. If I open this in acad I see 3d lines, but if I bring it into a blank revit project I don't see anything, if i explode the dwg I see some end caps but its not usable. Is there a workflow published for this type of coordination? Or do I just tell them to do it in Navis?
Civil 3d / 3D dwg coordination in revit
Tags: None
Probably a C3D dwg with "smart" Pipe object in it. For coordination purposes have them make the Pipe Network into Solids to export to .dwg. That way you at least have the geometry.
https://knowledge.autodesk.com/suppo...99BF8-htm.html
Originally posted by sdbrownaia View PostWe are being asked
Pipes from Civil 3D wont show up in Revit, without bouncing around to other formats like (possibly) IFC or something else. Or bring them in as Navis files, and then youll need to use Shaded mode. But "pipes" have never come over, that ive ever seen.
Originally posted by Twiceroadsfool View PostBy who?
Sent from my iPhone using TapatalkGreg McDowell Jr
about.me/GMcDowellJr
Pipes from Civil 3D wont show up in Revit, without bouncing around to other formats like (possibly) IFC or something else. Or bring them in as Navis files, and then youll need to use Shaded mode. But "pipes" have never come over, that ive ever seen.Scott D. Brown, AIA | Senior Project Manager | Beck Group
We had some issues recently with a DWG link being WAY WAY WAY too big (317.4 MILES!!!) We open the dwg file and go about trying to wrangle in the extents...
Channel: Tutorials, Tips & Tricks
January 16, 2014, 04:00 PM -
We have received a 3D dwg file of that we a re supposed to work of. The dwg file is native autocad.
Does anyone know if there is a way...September 18, 2014, 09:50 PM -
morning guys, first post on here!
I'm working on a project in revit 2014 and i'm wanting to import/link drainage design which has been done...-
Channel: Coordination Tools
June 20, 2014, 07:43 AM -
OK you translation gurus, anyone have a suggestion on how to turn this 3D DWG into a useful Revit family? Each segment is a 3D Solid in Acad, but when...
December 8, 2010, 06:49 PM -
I raised the issue/problem in another post but now we have another job with the same situation.
External slabs for industrial...July 21, 2011, 12:41 AM
