I'm trying to make a multipurpose valve that can switch between being straight and angled in the family. Everything works fine except for one thing: the single line line work does not behave, specifically the part that rotates. I kinda forgot about needing the line work until after I'd made all of the geometry, but even starting in a new family, the rotating line just does not want to behave/wants to break everything.
I don't know if the reference lines are hindering the symbolic lines from working correctly, but everything works fine if I don't have the symbolic lines in.
