I am exporting a Revit drawing that contains a raster image to dwg format. When the dwg is opened in AutoCAD, the raster image is rotated or not there at all. I can't select it in AutoCAD to move it into the correct position. Is there anyway to prevent this from happening when exporting a Revit file?
Exorting Revit to Autocad
I kind of like the idea of "Extorting" as the only reason to use AutoCAD.
But seriously, folks.
I can't explain why it rotated upon export, but if I remember my command line correctly, there's a SETVAR name IMAGEFRAME that determines if you can select an image and/or it's outline. Don't remember which setting does which, but its either 0, 1, or 2Dave Plumb
BWBR Architects; St Paul, MN
Originally posted by DaveP View PostI kind of like the idea of "Extorting" as the only reason to use AutoCAD.
I can't explain why it rotated upon export, but if I remember my command line correctly, there's a SETVAR name IMAGEFRAME that determines if you can select an image and/or it's outline. Don't remember which setting does which, but its either 0, 1, or 2Last edited by Andres Franco; October 12, 2018, 09:16 AM.Andres Franco - Architect - BIM Coordinator
E.A Poe
Are the GUID's exported to .dwg from Revit and if so does anyone know where in the .dwg they are?
December 16, 2016, 03:37 PM -
Dear All,
I am facing the problem in exporting raster images from revit to autocad (company logo in titleblock, rebar shape in bbs,...).
When...February 29, 2016, 07:25 AM -
Hi all,
I encountered a severe problem today exporting from Revit to AutoCAD (DWG).
As shown in picture #1, in Revit all texts...January 16, 2021, 09:29 AM -
We have received a 3D dwg file of that we a re supposed to work of. The dwg file is native autocad.
Does anyone know if there is a way...September 18, 2014, 09:50 PM -
Hope someone knows a good practice to get link dwg into Revit. Some DWGs when linked turn up distorted in revit. I have tried exploding,...August 22, 2016, 04:24 PM
