Hi not sure if you can see these images big enough but we are having a issue with the fire dampers.. the triangle symbols shading not showing completely solid black.. some are half tone and all the color line weights are the same for each one. see the variations in the triangles shading.. How would I change the shading to match the darkest one in the template or settings? They are not set on halftone.. the duct line weight matches all the other s/a e/a r/a and the shading is light?? Please respond.
Revt M.E.P. Fire damper color shading issue
As mentioned above it will be easier to find the issue if you could share the model or at least the fire damper family.
Looking at the images you provided it looks like that dampers at similar elevations look the same.
So you either have a filter that effecting the display of FDs or the family been put together in that way.
Have you tried playing with view range to see if anything change?
Hello Everyone,
I am new to the forum and in need of some help. I work at an MEP company and we recently started using Revit MEP to design...-
Channel: MEP - General
December 12, 2016, 11:00 PM -
I am setting up our section view templates and I've come across views in which ducts and duct fitting, both projected and cut, are showing up blue and...June 5, 2013, 02:26 PM
I currently have an MEP Color Schemes display issue. The attached snapshot above shows a plan view (medium level of detail)...-
August 30, 2019, 01:50 PM -
How come I can't override the color of my piping rise and drops? Please help. I can turn them on and off but can't change the color or pen weight of...
Channel: Tutorials, Tips & Tricks
October 17, 2012, 03:49 PM -
I hope someone could help. We are working in a project fully developped in RVT 2016 and the deadline is quiet tight. I detected yesterday something that...September 7, 2015, 07:05 AM
