Shared Coordinates from Revit to Navisworks
    Hello all,
    I have a Revit georeferencing model , I export to NWC with Shared Coordinates.
    In Navisworks I have also sets Shared Coordinates for the Revit files and Dispay Units: meters.
    When I select the model in Navisworks > Units and Transform > the units are in Feets (why?) but the coordinates are correct (if I try to change the Units in meters , the coordinates change) - Only the rotation is different but if I sum the Rotation in Navs + Rotation in Revit it gives me 360...So I suppose that it is correct..
    When I go Output : Google Earth KML, In the Google Earth Coordinates I have the coordinates that I have given in Revit in the Location Panel
    And in the Navisworks origin I have 0,0,0 . Is it correct? I was waiting to have the coordinates that exist in the Units and Transform dialog box.
    My purpose is to export the model in Google maps..
    Output kml function doesn’t work- better to output and locate visually
      Could you please give more details for what I need to do?
      Thank you!
