Bug?
    Bug?
    Has anyone else seen issues where Revit will delete detail components, texts, dimensions etc on multiple views/sheets? I have deleted text on a sheet and it appears to be deleting text on multiple, as well as copying detail components to other views for reference, deleting them out of the new view, and they are then deleted in the original view. Anyone know of a fix for this?
    Thank you
    Are any of the views dependent views?
      No and I have always made it a practice to almost never use dependent views
        Detail Groups?
        Cliff B. Collins
        Registered Architect
        Autodesk Expert Elite
          I had my keystroke set to select all in project and not select all in view. I'll let myself out.:banghead:
            Right click...………...
            Cliff B. Collins
              Problem
              In
              Chair
              Not
              In
              Computer
              Dave Plumb
              BWBR Architects; St Paul, MN
                Originally posted by DaveP View Post
                Problem
                In
                Chair
                Not
                In
                Computer
                Dave, support...it's no picnic is it?
                or PEBKAC
                Problem
                Exists
                Between
                Keyboard
                And
                Chair
