Hi!! I'm trying conceptual massing like for the first time & I need a little help!! I'm trying to make the form that is attached in picture. I'm trying to achieve the curve profile of building. Can someone help me considering this is an emergency.??
how to create a curve elevation in massing?
I see that your question has been without an answer for more than a month, so, this information comes too late for you. But anyway,...
1) Bring your sketch as an image to an elevation view in the generic adaptive template (or in the mass template if you are interested in creating mass floors and schedules).
2) In the elevation view, scale the image. You can use that human figure that you drew, as a reference for the scale.
3) Draw reference lines or splines tracing over the image, to form those closed shapes that you see on the second image.
4) Select those shapes, and do Create Form. Add other elements as necessary, voids if required, etc.
5) Load the family into a project, and convert faces to walls, floors, roofs, etc.Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
Originally posted by aditya_31Same query hereFreelance BIM Provider at Autodesk Services Marketplace | Linkedin
Hello Revit gurus,
Can some one shed me a light on how to make this form native in Revit? I am having a hard time to fillet the slope line(from...June 11, 2014, 08:28 PM -
I am having an issue with my cornice appearing on my sheet elevation.
As you can see in the screen clips, the upper cornice is only set back...October 24, 2018, 09:06 PM -
Is it possible? I tried using the Fillet Arc command and nothing happens, it won't let me select any lines.
I'm interested in pushing what...January 10, 2015, 02:41 AM -
I'm currently working my way through the Revit Architecture 2013 Essentials book, and having reached chapter 2 on Schematic Design I'm having a real problem...November 26, 2012, 05:18 PM
Dear All, I'm trying to follow the advice of Revit followers to produce all stages of a project, from concept to construction. I have used Revit architecture...March 19, 2013, 12:11 PM
