Beam stick symbol VG
    Can someone confirm that stick symbol VG is not effecting beams?
    I'm trying to change their representation, but to no success.
    In the attacher you can see a section view with Stick symbol on/off for StrColumns and StrFraming. The beam stick symbol is unaffected.
    The family I'm using is an ootb family (IPE beams) but have tried with other steel beam families as well.
    In the family there is no Stick Symbol line at all. I suspect this is part of the reason I cant change it in the project.
    What's going on, anyone knows?
    Thx in andvance.
    Easy things are not worth the effort
    http://www.teamcad.rs/
    You need to add a stick line in the family.
    We set the Subcategory of the line to “Defined by Instance”. This means it will take on the representation of what the Structural Usage is set to.
    JH
