Parameters and constraints
    Is the only way to constrain an element to place a dimension on it and then add a parameter?
    Can you not constrain an element by attaching it to another element so that if the first element moves, the second does also?
    Must parameters be applied in sketch mode, if you try to add them later it is not possible?
    No,
    Yes,
    Maybe.
    too philosophical ...
    I think you should be more specific
    What are you trying to do?
    "-Bueno, pues ahora que los dos nos hemos visto el uno al otro -repuso el
    unicornio-si tu crees en mi, yo creeré en tí, ¿trato hecho?"
    Lewis Carroll
      Attach parameters to reference lines and/or planes. Attach the effected element to the line and/or plane.
