[All Verticals] - Copy Referenced View Keep Extension Line Settings
This topic is closed.
  • [All Verticals] - Copy Referenced View Keep Extension Line Settings
    Applies to: - All Verticals
    New Feature / Problem:
    Copying a Referenced View (ie: callout created from Reference Other View) retains the extension line settings on paste so that if you have placed the callout bubble in a certain place, the copies are exactly the same.
    Why do you need this Feature / Why is it a Problem:
    The problem is that when I copy referenced vies, callout specifically, I have to rework the callout bubble every single time it is copied in a separate view, causing me to reposition every bubble in the exact location as the original.
    Workflow:
    Select Referenced View > Copy > Paste (to selected views|aligned|etc)
    Benefits:
    I don't have to do as much work when I copy a referenced callout across 20 views.
    Attachment comments:
