Applies to: - All Verticals
New Feature / Problem:
Copying a Referenced View (ie: callout created from Reference Other View) retains the extension line settings on paste so that if you have placed the callout bubble in a certain place, the copies are exactly the same.
The problem is that when I copy referenced vies, callout specifically, I have to rework the callout bubble every single time it is copied in a separate view, causing me to reposition every bubble in the exact location as the original.
Workflow:
Select Referenced View > Copy > Paste (to selected views|aligned|etc)
Benefits:
I don't have to do as much work when I copy a referenced callout across 20 views.
Attachment comments:
Workflow:
Benefits:
