Updating Title Block
    Here's a probably elemental question for anyone who's been using Revit for longer than my 1 month:
    How do you update a title block? I've edited my .rfa title block but my sheet still displays the unedited block. I'm looking for something analogous to Autocad's block updating...
    thx, Will P.
    You have to reload it into the project after you save the title block. If by chance the title block in the project isn't the one you have updated, after loading it into the project, open a sheet in the project, select the title block and change it to the one you want.
      And if you want to edit the text, you should use Parameters and Labels. They can be changed in the project.
