Boolean Functions
    Boolean Functions
    I am trying to run a Rough Width parameter for different types of doors off of multiple Yes/No functions for door type. I need to make the Rough Width ex: (Width + 1.5") But the '1.5"' will vary depending on the door type. What formula layout must I use for this? I have tried if(Wood, Width +1.5"),if(Steel, Width +2") but I get an error every time. Any help would be appreciated.
    Thank you
    To add, I need these all to schedule under "Rough Width" so I am not able to make multiple (1.5",0") statements with a Rough Width 1,2,3.
      You’ll need additional parameters (not text) to differentiate between the constructions and use a nested if statements.
      if(wood,x”,if(steel,y”,z”)
      wood and steel in this example are yes/no parameters — not the best choice but doable
      Greg McDowell Jr
      about.me/GMcDowellJr
        Thanks, I got down the rabbit hole of and's and or's but this much easier
