I've been asked to help figure out why the OOTB Siamese Connection course mode linework does not scale with the annotation scale. Other fittings do, double Tee, etc.).
The FDC is a plumbing fixture but if you change the category to pipe fitting or pipe accessory, it still does not scale.
Has anyone else run into this? The linework in the families are all "Pipe Fitting" and the family has "Use Annotation Scale" checked yes.
Thanks.
Thanks.
