Hi, I have a set of AutoCAD Surveyor Drawings and I am supposed to model the existing building based on that. However, there are many places where when I tried to align the wall, (even not tracing the lines, just trying to match closely), Revit will give me these warning" Warning: Element is slightly off axis and may cause inaccuracies."
The length of the wall is about 18meters and if I correct the wall in revit, start from one corner, draw to the next corner, in order for revit not to produce any more warning, the wall at the 2nd corner is about 50mm apart.
What should I do? on one hand I want to match the surveyor's dwg, on the other hand I don't want my revit model full of warnings before it even kick off with the new design...
