I have over 100 sheets that I need to renumber, but several groups of sheets have a number with a x.1, x.2 suffix and so on. I'd like to renumber the sheets while maintaining those number suffixes. Is that possible with Dynamo or macros?
Renumber sheets while maintaining x.number suffixes?
Originally posted by PatrickGSR94 View PostSo I might have sheets:
117
118
119.1
119.2
120.1
120.2
and I need to stick a sheet in after 117, so all the sheet numbers after 117 need to increase by one, but the .1 and .2 needs to stay the same, so 119.1 becomes 120.1 and 120.2, and 120.1 becomes 121.1 and 121.2 and so on.There are no stupid questions, only stupid people
This is how it looks in the player.
This should do it, fun little exercise to quickly build. Only needs a single Clockwork and Rhythem node. Rest is OOTB. Dynamo 1.3.3, Revit 2018.3
If you want my Revit test file give me a shout, just a little to big for the upload limit.Attached Files
Originally posted by PatrickGSR94 View PostOh well, I went ahead and just renumbered the sheets manually. 100 sheets only took about 5 minutes to renumber in a schedule, starting at the bottom and going up, increasing each sheet number by 2 so that I could add in 2 sheets.
I love a good challenge, but next time: please let us know if you're really stuck, or you are just venting frustration......
-People here actually do hard work to help each other out, please respect that.
I know (hope) this there is a simple answer for this issue. I need to find out if there is way to organize the sheets, in the browser (not the sheet...July 13, 2018, 09:47 PM
What addins/apps are people using for sheet creation? Also, is Revit really limited to creating one sheet at a time?February 18, 2016, 08:49 PM
Is there any app or macro that creates multiple sheets at once.September 28, 2016, 06:58 PM
So, here I sit on the weekend toiling away at updating our sheet index (need to add ~400 sheets to it). Is there any way to quickly replace text in multiple...September 21, 2014, 06:43 PM
Dumb question on renumbering sheets: Usually when I need to renumber sheets it is because I have to add a sheet which throws off my sequencing. I can...
Channel: Dynamo BIM
March 30, 2017, 08:30 PM -
