CAMduct Automactic Nesting Problems
    I'm on the CAMduct these days, there's some problems i can't solve.
    After Automactic Nesting, showed ''There is nothing to Nest'', idon't know where is wrong, do anyone knows why? see the attaches.
    CAMDuct interfaces with Revit or is it a totally separate Autodesk product?
    If it interfaces with Revit, did you start with an Mechanical Template? If not...might suggest posting on the Autodesk Forums instead... https://forums.autodesk.com/t5/fabri...forum/bd-p/165
      What's in the Job Contents of the MAJ you brought into CAMduct? Did the MAJ exported from Revit contain duct fittings? Is CAMduct using the same configuration as Revit was for the Fabrication parts?
