Wall tags not showing up on Prints
    Hello revit users,
    This has been driving me up the wall-
    the wall tags aren't showing on my pdf's.
    It appears to be completely random, I've tried un checking the show unreference views parameter, sometimes it works sometimes it doesn't. Maybe it has to do with that?
    It's only the wall tags that aren't printing which is a bit of a mystery to me.
    Has anyone else had this problem, i'm sure it's an easy fix.
    Thanks guys!
    Yep - Had this problem, but for Keynote Tags in Plan Views that were Wall Hosted
    Solution - Na not yet. we tried printing to raster, and that worked intermittently
    Dwane
      Show/Hide unreferenced views refers only to view references like sections and elevations. If you set them to hide, then any view not on a sheet will have its section or elevation mark hidden when printing. That doesn't affect tags.
