Hello Everyone,
I am new to the forums and hope that I am posting to the correct place! I am trying to create a Label as part of a new titleblock family that feature text that is both bold and not bold, such as...
OPTION1A_Guest Room Layouts
I know I can concatenate two shared parameters (heading, subheading) in one label but then it is either bold or not. Alternatively, I could split them into two labels but then I am at a loss as to achieve consistently tight spacing when text fields shorten or lengthen.
Ideally there would be some markup tag (\b?) I could enter into the text of the parameter to achieve this...
On a related note, the firm i just joined (which I am helping transition to Revit!) has a graphic convention of showing project names on their existing title blocks similarly. For example a project called NLHouse, would appear NLHouse. Any Ideas on how this might be achievable, other than a static text field on custom per project sheet? I am trying to duplicate as much of their graphic standard as possible, without having to create unique sheets for each project.
Thank you in advance for all of your help
