Roof design question.
    I am having trouble with merging the porch roof with the main bulding roof. I've attached the file an a screen shot. Any ideas?
    Use the Join Roof Tool
    It's Located on the Modify Tab, Geometry Panel, and the Tool Icon Looks like a Small Roof Plan
    Start the Tool, Pick the Back Face Edge of your Porch Roof, them the Face of your Larger Roof
    It should automatically Extend the Porch on to the Larger Roof
    Hover over the Icon & watch the Video Play
    Dwane
      I find that sometimes the Roof Join tool won't work if the two roofs touch each other initially. Sometimes it works and sometimes not so I generally try to pull the smaller roof away from the main roof, and then use the Roof Join tool. For those porch roofs you can join both the back edge and the end to each of the respective roof faces. I would probably do the back edge first, and then the end.
