Revit 2019 steel tab
    I just started to use Revit 2019 and my tools inside the Steel tab is not working.
    Am I missing anything?
    I noticed it is kinda finicky when selecting the structural elements...but I usually don't work with structural. Probably works best if you start with a structural template perhaps?
      That's a good starting point. You can also download any updates and extensions related to steel components. If the tab still doesn't work, then I would report it as a bug on this forum and do a clean re-installation of Revit.
      Which Direction Will You Choose?
