I have various Face Hosted electrical/fire alarm families and in particular case the architect has changed the Base Offset of the hosting wall to -10'-0" to show walls for a crawlspace below. The family in this case is changing elevation following that -10' Base offset. So it was originally placed at 4'-0" elevation...After this architectural model update which changes the base offset of this wall in question the families move to -6'-0". All levels in host model have not changed and are correct.
Faced Hosted Family Changing Elevation with Base Offset of Wall
I assume you’re asking if that’s supposed to happen? Yes, it is. Does it make sense? Yes, and no. Depends on what you’re doing.
There’s a general move away from face based families for this and other reasons.
An unhosted family wouldn’t have this issue but you have to track its location relative to changes in the wall. Pick your poison.
Sent from my iPhone using TapatalkGreg McDowell Jr
about.me/GMcDowellJr
Originally posted by cellophane View PostWhat causes that change? I've seen it in the past and it's always bugged me, but when trying to replicate it just now (2019.0.1) I couldn't get it to move the family when changing the wall base offset unless I change the actual base level. :crazy:
https://www.screencast.com/t/GWlq4eDZ5
Fix with Revit 2019 maybe, my example was 2018.3........one of the guys in office has a saying "It is Revit just Reviting"
I have seen Paul Aubins, work around for getting a wall based family to facebased or un-hosted.
but is there anyway of getting a face based...-
Channel: MEP - General
May 11, 2019, 08:56 AM -
Hello
Please could somebody help me find out what the cause of this problem is.
When I place a door with offset of 0 the finish...March 30, 2017, 05:40 AM -
I moved my project base point and survey point to a corrected location (elevation).
The floor (spot elevations) and level elevations are...-
October 7, 2016, 08:07 PM -
I have created a family that is intended to be placed on top of other families. In this instance a lamp on top of a desk. When I created the lamp family...December 26, 2012, 05:44 PM
I am trying to create new families for the company I work for.
I want the ability for the symbols to be offset from and/or along the wall/ceiling...-
Channel: MEP - Family Creation
November 13, 2019, 01:15 PM -
