Hello,
I will be starting a new project soon in Revit. One of the requirements is that we will need to provide a pilaster and anchor bolt plan. The way that my firm does it now, is that the plan is at a larger scale then the foundation plan and also pilasters are cut out, using break lines to cut the walls. What would be the easiest or best way to do this?
I was thinking of duplication the plan and using callouts at the pilaster locations and placing the callouts on the sheet but that seems to be a lot of view managing to get the layout of the plan correct.
Thanks
Thanks
