Hey guys,
Wondering if anyone can help here, I'm looking at a custom .ini file to get custom colours and default template locations etc.
One piece of the puzzle I haven't fully understood is the Section - Setting,
"[Install]
InstallGUID= XXXXX"
Is this required to be in the .ini file?
Unfortunately the company I've just joined have not deployed Revit across the office of 180, instead the IT guy has been installing computer by computer over the last number of years (Separate problem altogether :banghead
But as a result & from what I've read online the users won't all have the same InstallGUID.
As a result I was intending to set up a .cmd file that a user can run to replace the .ini file in the UserDataCache & to replace the .ini file from the Appdata/Roaming/ etc. anyone see any issues with this? (I'd ideally rather this was all part of a deployment, but as per above it's not currently feasible).
Thanks in advance,
NotGeoff.
"[Install]
InstallGUID= XXXXX"
Thanks in advance,
NotGeoff.
