What Revit Wants: Replace Existing Sheet and Retain Waypoints with HoloBuilder
    We have been using HoloBuilder to capture as-built conditions on a huge hospital project, in order to maintain the federated BIM dataset (BIM to FM / Asset Information Management). 360 photos are a very quick and easy way to capture the context of building elements, but not their geometry.
    This tip comes from one of our local HoloBuilder experts, Lisa Verschoor:
    How to move across an updated drawing/sheet in HoloBuilder and have the already existing waypoints attached to the earlier version carry over automatically
      • Open HoloBuilder
      • Select sheet you want to replace (in example pic below I’m replacing sheet 020-H-003)
      • Click on the “Exchange this sheet” button (two opposing arrows)
      • Prompt will ask “Do you really want to replace the current Sheet with a new one?”
      • Click Ok
      • Now drag and drop updated sheet
      • Select High Res option
      • Ok
      • All done!
    The post Replace Existing Sheet and Retain Waypoints with HoloBuilder appeared first on What Revit Wants.
    Author of What Revit Wants
