I want the view title to be able to be made multi-line on some views, and not on others and adjust each time. Is this possible? I don't see any advantage to it not being instance based.
Make viewport title multi-line as an instance-based parameter
There are quite a few posts about this already... I would suggest using the search function of the forum, but even I get terrible results. Go to Google and type Revitforum then what you are looking for... But this one Chad shared his family. https://www.revitforum.org/architect...iew-title.html
But it won't adjust automatically.Michael "MP" Patrick (Deceased - R.I.P)
Originally posted by MPwuzhere View PostThere are quite a few posts about this already... I would suggest using the search function of the forum, but even I get terrible results. Go to Google and type Revitforum then what you are looking for... .
search terms you want site:revitforum.org
the other method works but you will get other results included (which isn't a bad thing, just something to be aware of.)
Edit the family and widen the text "extents". You'll have to play with this to figure out how far is far enough. Change the text so it vertically aligns to the bottom.
Use title on sheet option and using ctrl-enter for the second line. You can't force hard return with the view name because it's tied back to the project browser.
Many moons ago I set an office up with viewtitles that were either 6, 8 or 10 inches long. No more, no less. They used the right one for their purposes. It also drove those OCD guys crazy until they standardized the sizes of their details. And wouldn't you know it, a couple sheets out of 100 sheet set vanished. Funny how being organized helps. All because they couldn't make details silly widths without it driving them nutsMy ID was stolen. Now I'm only called Dav
So I'm trying to edit a current view title so that I can change the "title" without changing anything in my project browser.
Channel: Structure - Family Creation
October 3, 2011, 04:26 PM -
For some : I am working on placing view titles for interior elevations, and some of the titles are long, so I want to make them multi-line without...July 18, 2018, 03:46 PM
When I drag my drawings onto a sheet the viewport title that comes with it sometimes wraps & sits over or very close to the scale text below it....March 14, 2011, 05:22 AM
Hey Community;
im sure this question has been raised; but i was trying to make a custom view title for a project template. basically trying...-
April 16, 2019, 09:08 PM -
I have been asked to incorporate a parameter in the viewport type that references to a detail/view in the construction documents as shown in the doc....April 4, 2011, 07:00 PM
