Terminate top railing to host
ID:	419219 How can I make this work? Is there a way to eliminate the joint between the top rail and the end baluster?
    Nope, sorry. I think the contractor will forgive you.
      Create as and in-place family (change category to railing) and create the sweep exactly as you'd like.
        Use the linework tool and make the line of the joint invisible in the views where you see it.
        Jeff Hanson
        Sr. Subject Matter Expert
          Originally posted by JeffH
          ...Use the linework tool and make the line of the joint invisible in the views where you see it...
          Since you brought it up, I was going to mention that in my reply but the look of disgust (or words) I get from people whenever I mention that tool that shall not be named has me somewhat at odds with it...
