I have attached an image of what is happening when I am printing my duct work to PDF. I am wondering if anyone has come across this before and how to fix it.
PDF Printing issue
the attached .png is difficult to see (plus I'm Structural) and I'm not sure what the issue is. Can you give more explanation about what is happening/what you expected to see?Leanne Zaras, CDT, LEED AP
ah. okay. Looks like there is some info from elsewhere in the model that is interacting with the .pdf plot.
So, here are a few questions:
1. which version of Revit are you using? Have you upgraded the model? (wondering if the previous plot came from an older version.)
2. how are you creating the .pdf? Are you using a .pdf printer like Adobe, or CutePDF, or Bluebeam?Leanne Zaras, CDT, LEED AP
Originally posted by LeanneZ View Postah. okay. Looks like there is some info from elsewhere in the model that is interacting with the .pdf plot.
2. I am using Bluebeam. The only change on my system that I can think of it I just had a windows update yesterday but I have no idea what was actually updated with that.
I did check with my newer projects that are in R17 and it printed to Bluebeam PDF just fine.Last edited by mhoard; August 15, 2018, 07:25 PM.
Originally posted by TFuller View PostIt would appear that you are now printing structural elements in addition to the arch and HVAC. Is this a new linked model or have you modified your view to include those elements/link?
I looked around, and didn't see much on this. So I'll ask the masses here..
I'm having an issue with printing to a PDF, from Revit.....and...March 26, 2021, 07:13 PM -
Hi, My team has run into a strange issue which started with one person but has now spread to most of the team. The issue is not limited to printing to...March 17, 2021, 10:33 PM
I printed a couple camera views and when printing to a PDF (Bluebeam) there is some triangulation / faceting in several areas that does not appear if...January 19, 2015, 01:43 PM
My company has taken over a job by a previous engineering firm. They have some pre-existing PDF's that are superb quality and I just can't get it quite...May 17, 2012, 04:35 PM
I'm having trouble with .pdf files, when plotting papers bigger than DIN A2. Paper formats smaller than A2 are woorking fine!
Channel: MEP - General
May 8, 2015, 06:23 AM -
