How to create Calculated value formula
    Hello all,
    How to create calculated value in Schedules by using Count parameter? I knew that count cannot be used as a fields but any other alternate method is available to proceed further. Please help me in this case.
    Thanks in advance
    You can’t.
    You can work around it by setting a new calculated value to 1, totaling that column, then another calculated value that shows to percentage of the “1” parameter relative to the total/sub-total, and finally one more calculated value that takes the invert of the percentage (1/%) which will give you the total/subtotal in each row.
    That was from memory so I might have missed something... if I remember I’ll share an example later today.
    Greg McDowell Jr
    about.me/GMcDowellJr
      There are several threads about a solution to this.
      (Also known as the "Total Mayhem" solution, so you can search for that too.)
