Blank Leader
    Blank Leader
    Maybe I'm just suffering from #BILTNA hangover, but I swear there was a new feature recently (2018?) that allowed you to place a Leader Line with no text.
    [email protected]#$%!#$ if I can find any reference to it though. Am I dreaming?
    Dave Plumb
    BWBR Architects; St Paul, MN
    Place text with no text...
      :banghead::banghead::banghead:
      I swear I tried that!
      Dave Plumb
        I don't like the leaders that come with text, I still use the old leader family and keep it independent as I find it helps with alignment. Just my own preference.
          empty GA family...am I missing something??
            It's the old way, place an empty symbol family, add a leader...
              Yep that's all it is, remember to set the options bar to 1 or nothing appears. I did try the built in leaders but found it lacking so in this case for me the older method is better.
                that's pretty slick, thanks for the direction!
