Applies to: - All Verticals
New Feature / Problem:
Need the ability to reference a drafting view location in a door schedule. (Or any schedule for that matter)
Currently our only method of calling out head, jamb and threshold details is a text only parameter that as long as nothing changes on the sheet works out okay, but if views get moved around can cause issues and headaches when checking over 500 doors.
Workflow:
When you select the cell where the parameter is located an interface very similar to "Reference Other View" of a section or callout would appear and you can select the proper drafting view for that door.
Benefits:
Depending on whether the parameter is a type or instance can streamline the detailing process of doors where like door types will automatically fill in details for similar doors. If instance, if a drafting view location on a sheet was moved around it would automatically update on the schedule.
Attachment comments:
Workflow:
Benefits:
