Since the beginning when I started Revit 2017 I couldn't get my sun & shadow working. It always come up with this error (Third party updater "Sun and Shadow Settings Updater" has experienced a problem and its action had to be canceled.) & then disappears. What can I do to get it to work?
Sun & shadow
Update your version of Dynamo: Dynamo BIM
Users reported that: Revit gives the following error when applying Sun settings in a project: "Third party updater 'Sun and Shadow Settings Updater' has experienced a problem and its action had to be canceled." Steps to reproduce: ( both with Dynamo 0.9.0 and 0.9.1.) Start Revit with Dynamo installed New a project. Go to default 3D view Click View->Render->Choose a sun location->Choose Sunlight from Top Right->Select "Level 3"->click OK Status: This issue has been fixed in Dynamo 0.9
So really liking the noticeably speedier 2017.2.... but getting an error w/ sun adjustments, anyone seen the same/know what's up/know how to "fix"?...March 31, 2017, 11:38 AM
I keep getting an error when I try to modify my sun settings in a project. It only seems to affect a single project but I would love to be able to modify...September 4, 2015, 08:12 PM
So i have recently installed revit 2017 and i notice dynamo does not seem to latch on to it like 2016 any one else having this issue?
Channel: Dynamo BIM
May 11, 2016, 07:56 PM -
Previously the Dynamo installer would include a version of IronPython in the install, and I think the Dynamo web site also provided links directly to...
Channel: Dynamo BIM
January 25, 2017, 10:46 AM -
When I click on Manage > Dynamo, version 1.2.1.3083 opens (it says Dynamo Core and Dynamo Revit are 1.2.1.3083). Shortly after it opens, the little...
Channel: Dynamo BIM
August 1, 2017, 04:10 PM -
