Duct Colors
    Duct Colors
    So unless I'm going crazy (which is very well possible) I seem to always remember that supply duct was drawn as blue and return duct was pink, as a standard. I am in a project and just got into laying some duct work out and it is all showing as grey. Does anyone know how to get the blue/pink back?
    We use filters with a color and solid pattern to get colors on pipes and ducts. The filter looks for the system name.
      I wish. As the architect who gets the models down stream this would make my day... maybe my hour. The way most I’ve worked with are doing it is directly by the system type which I then have no real control of when I link their model into mine. Boo
      Greg McDowell Jr
      about.me/GMcDowellJr
        As an architect, I’ve provided special views to consultants that have filters set up to show fire rating, for example. You might ask the consultant to do the same?
          You can override the linked file system colors by Filter: I do it all the time - you just have to find a common value to filter by
          Alex Page
          RevitWorks Ltd
            I discovered a nice way to control linked colours recently, when linking MEP models into each other (With system filters for pipe and duct colours).
            The most reliable way to filter any type of elements across linked models is with 'workset', but this only works if you have worksets with the same name in the host and link models.
            So.. Name the active/main workset in each model the same as the model name.
            Whenever you link a model, put it in a workset that is also the same as the model name.
            Now you have consistent workset names in all your models and you can filter each link to look however you like.
            (For example show, but grey out mep models from other surrounding buildings. Or link new and old versions of a model over each other, filter one to be red so you can see changes. Or just make links consistently grey/thin lines without using the halftone settings)
              Seems like a lot of work. Filters can override the Graphic Overrides of MEP models. Easiest most consistent way.
              -TZ
              Tannar Z. Frampton ™
              Frampton & Associates, Inc.
                • Issues with duct lining
                  I received my model from an engineer or architect (not sure which) that contained a layout of the duct system in a building.
                  The specs require...
                  February 14, 2012, 02:46 AM
                • Stuck with this
                  I have a case where a piece of rigid duct is replaced by number of (could be 4,5 or more) flex ducts. I have to use a round duct tap....
                  April 27, 2018, 04:49 PM
                • Duct Accessory Without Duct Ends Visible
                  Is there a way to create a duct accessory family which stop the duct ends from being visible? I've tried masking up it had some strange affects. The only...
                  June 27, 2019, 06:36 PM
                • Revit - MEP - Oval Flexible duct
                  Hello Guys!
                  We need on our project Oval flexible duct!
                  Do anyone knows is there a way to do other profile to flexible duct?
                  September 16, 2015, 04:14 PM
                • Still no duct bank capabilities??
                  Is it just me or is there still no tool is available for creating underground duct banks. :banghead: I've gotten away with using HVAC duct but I want...
                  November 2, 2012, 04:00 AM
