Hello, again I've got a question about opening families.
Is there any way to create a family that will cut sloped floor in vertical axis and ensure proper working of "invisible line underlay trick"?
If I create wall based gm, and untick "always vertical" it's axis is going to rotate perpendicularly to the host floor and then invisible line trick is going to fail. It's just not showing underlay, what is logic.
So can i create any "always vertical" family that will work with sloped floor host?
I just thought about sth during that typing...
Will combination of "always vertical" underlay child family, and non "always vertical" opening parent fimily work if nested? :laugh: Or parent family will override vertical properties of nested family?
Cheers
Cheers
