Wondering if anybody has a better way to do this.
In the wood frame projects we're doing the floor has both a fire rating and an increased sound rating. The first is accommodated by a sheet of 5/8" GWB on metal furring attached directly to the bottom of the structure (which varies in depth across the building). The second is additional insulation above this layer.
I would like to track as few things as possible. Modeling a 2" floor (plywood and gypcrete), a ceiling, and something (presumably a ceiling) for the insulation is two things more than I'd like (but I can get over that).
Currently we're doing it all as a series of thick floors but we've also been ignoring the varying structural depths up until now and I'm starting to wonder if that's really the best approach. Perhaps a single 2" thick floor and a series of thickened ceilings (ideally automatic rather than sketch) would be a better approach. The downside to the ceiling is that I now need to manage it's height above the floor but perhaps, all told, that's less work than potentially hundreds of manually placed floors.
Thoughts?
Thoughts?
