Hi there,
I'm having a persistent issue which is making my studies almost impossible. When attempting to change Temporary Dimensions between walls I get the following message - Can't change dimension segment to this value.
I have searched high and low for a solution, but although there seems to be much complaint about it, no one seems to have an answer. If you do I would love to test it out.
In the example below I was attempting to change the value from 6' - 3 15/16" to 8'
Thanks.
Thanks.
