Do I need to upgrade to 2017 before going to 2018 or can I upgrade models from 2016 directly to 2018 without issues?
Upgrading model from 2016 to 2018
I believe it's "recommended" to go one step at a time when upgrading, but I've done many, many projects directly from 16 to 18.
If possible, clean up as many of the Warnings a you can (which is good practice regardless)
Make sure you check the "Audit" box when doing the upgrade.Dave Plumb
BWBR Architects; St Paul, MN
I'm in the process of updating from Revit 2016 to a newer version.
Personally I've never had any huge problems, but recently I've...-
April 25, 2017, 10:01 AM -
Hi All,
I have recently installed Revit 2018 and first thing that I tried to do is to upgrade my Revit template from 2016 to 2018...-
Channel: MEP - General
April 19, 2017, 08:13 AM -
I have a user who is running Revit 2018 and 2017 at the same time. This causes Revit 2018 to freeze. Did I forget to mention that they are also running...May 15, 2018, 09:26 PM
HI GUYS,
I am trying to Upgrade my Revit 2015 project to Revit 2016.
but from my previous experience, Upgrading is not recommended....January 12, 2016, 02:46 PM -
This isn't directly related to Revit, but I know a lot of AEC uses Bluebeam Revu (PDF software).
I've been using it for a few years, and...-
Channel: Out There
January 9, 2019, 06:52 PM -
