MEP elec : Electrical wires and Electrical Conduit/pipes
    Good morning everyone,
    I have recently started the first BIM project of my company, we will be doing the electrical works. I just concluded a training in Revit MEP. The trainer did not have necessarily all the answers i could had expected so i will post a few subject on the forum to get some help. Tell me how you would do, using Revit or some pluggins etc ...
    How would you manage the setting up of actual electrical wires in the model ?
    As an electrical company, to realize a good project certain amounts of parameters need to be known such as the length of the electrical wires of the project. Because we have to buy and install them.
    A BIM model and a tool such as Revit should give those kind of information.
    I know that in the power circuit of Revit, one can get an rough estimation of the length of just this circuit. But the wires are just notes and not object. And there is nothing located on the model, we don’t know where the wires go, what types of wires etc ...
    I also heard that many are using conduit as a substitute for wires. Does it mean i need to create a family of object for each type of wire (single phased, three phased, flexible, stiff) and a type for each cross section of wire ?
    And then using a Quantity view on can extract the property of length of those conduit that act as wires.
    By doing so, for example how would you manage to put a wire inside an actual electrical conduit ? (Because in reality this is how things will be, an electrical conduit and inside one or several wires).
    How would any of you deal with the management of actual wires in Revit ? What is the proper methodology ? (Revit or plugin or other ?)
    Have a nice day,
    Thank you very much
    Regards.
  • Electrical conduits vs System wiring
    Hello
    First of all, I'd like to say that I'm an electrical engineer and a beginner in REVIT. I am in the middle of the transition between
    July 27, 2015, 04:24 PM
  • Question to the MEP Revit Users
    Hello MEP Community. Has anyone found a quick way to draw prefab electrical wire in Revit. We currently do this in Auto CAD using poly-lines to determine...
    January 30, 2019, 11:59 AM
  • Electrical Power Layout
    What is best practice for doing electrical power layouts?
    Do you go round placing all the sockets etc.. first then link them to the DBs?...
    July 22, 2014, 03:02 PM
  • electrical conduits.... flexible!
    hello
    i'd like to modelize electrical conduits but when i tried to did some i realised that they are rigid... you can't make any curves with it......
    September 30, 2019, 02:12 PM
  • Electrical imitating AutoCAD?
    Good Morning,
    The dilemma: I know little to nothing about electrical work. I haven't even ventured into that wading pool in Revit.
    March 13, 2015, 07:17 AM
